- 1 Jun 2010
- Bedford
Hi guys I really need your help as I am new to overclocking CPU
.I have Corsair DDR2 800MHz Gaming memory.
I am trying to overclock my E6600 to 3GHz for now which I presume is moderate overclocking from stock 2.4 GHz. So this means I would need to increase the FSB to 333 from 266. OK so yesterday I was looking forward to it when I realised that I am finding the MB intelligent tweaker (M.I.T) confusing
So far this is what I changed in M.I.T:
-I changed the CPU Clock ratio which I presume is CPU Multiplier to 9X (max).
-Enabled CPU Host Clock Control and stepwise increasing FSB by 10MHz. So currently CPU-Z is showing 276 MHz and DRAM Frequency is 414.0 MHz. The FSB to DRAM is 2:3.
-Set PCI Express Frequency to 100MHz. However I don't see the option of setting PCI frequency
Rest of the stuff I just left it as it was. So the 'Robust Graphics Booster' is still on Auto and the 'Performance Enhance' is still set to Turbo. I was reading the overclock guide and it says that the memory divider should be set to stock or lower. So I gather that while increasing FSB the DRAM Frequency should be set to constant 400MHz stock value. However I don't know how to keep the RAM to stock value. Also how can I get FSB to DRAM to 1:1 or is there any benefit of doing so?
Finally how much my RAM can be overclocked before it becomes unstable or damaged seeing it has already increased to 414MHz?
Please help guys
Please help guys
