New 257.21 WHQL NV drivers
17 Jul 2007
Solihull-Florida
Get them form http://www.nvidia.co.uk/Download/index.aspx?lang=en-uk or http://downloads.guru3d.com/ Win32\64bit
"Upgrades PhysX System Software to version 9.10.0222.
Adds support for OpenGL 4.0 for GeForce GTX 400 Series GPUs.
Adds support for CUDA Toolkit 3.1 which includes significant performance increases for double precision math operations. See CUDA Zone for more details.
Adds a new NVIDIA Control Panel setup page for SLI and PhysX for ultimate control over multi-gpu configurations.
Adds a new NVIDIA Control Panel feature for ultimate control over CUDA GPUs, allowing the user to effectively choose which GPU will power each CUDA application.
Includes numerous bug fixes. Refer to the release notes on the documentation tab for information about the key bug fixes in this release.
Users without US English operating systems can select their language and download the International driver here."
I am installing now. I hope they are better then the beta ones
I like these drivers :)
I got a few FPS more(3) in Just Cause 2 and no problems with CS5 as I did with the beta ones.
I just installed these drivers. Dont know if this started with these drivers or the last, but in the 3d options i can only choose low/medium for ambient occlusion. I seem to remember seeing an option "quality" in the past. Also under the CUDA - gpu's option, all i can choose is "all". There is no other option. Again i seem to remember being able to choose either of my two cards. I never use this option, would just like to know that everything is working how it should be.
Phil.
ive installed for GTX470 that seem run lots fast and some good improve include in blu-ray, it better than the old one also the WEI which I refershed were from 7.5 to 7.7 (CPU and RAM are 7.5, Graphic and 3D gaming are 7.7 and HDD still at 5.9)
Anyone with a GTX280 on Vista or Win7 64-bit tried these out yet?
The last drivers 197.45 do randomly give me a screen flicker (goes black I think) in some games e.g. BF:BC2, so I'm thinking about giving these a whirl.
Win 7 64bit w/ GTX260 SLI and so far only played a bit of Eve Online and Modern Warfare 2 but both seemed to be fine.
I have 2 X GTX 280 SLi
Will have a play around and report back. ;)
Installed these and played BFBC2, I didnt seem to get any black screen flicker but its not often I get it so its still to early to tell, also didnt get a CTD between maps but again it doesnt always do it and I cant see that being a driver issue anyway but all in all looking good
GeForce 400 series:
GTX 480, GTX 470, GTX 465
GeForce 300 series:
GT 340, 315, GT 320, 310, GT 330
GeForce 200 series:
GTS 240, GTX 280, GTX 275, G210, 205, 210, GT 220, GT 240, GTX 260, GTX 295, GTS 250, GTX 285, GT 230
GeForce 100 series:
GT 130, GT 140, GT 120, G 100
GeForce 9 series:
9400 GT, 9800 GX2, 9600 GSO, 9300, 9800 GT, 9300 GS, 9100, 9600 GS, 9200, 9500 GT, 9300 GE, 9500 GS, 9800 GTX/GTX+, 9400, 9600 GT
GeForce 8 series:
8800 Ultra, 8400 SE, 8100 / nForce 720a, 8600 GTS, 8800 GS, 8800 GT, 8600 GS, 8200 / nForce 730a, 8300 GS, 8300, 8800 GTX, 8400, 8600 GT, 8500 GT, 8400 GS, 8800 GTS 512, 8200, 8800 GTS
GeForce 7 series:
7600 GS, 7950 GT, 7650 GS, 7050 PV / NVIDIA nForce 630a, 7100 / NVIDIA nForce 620i, 7300 LE, 7100 / NVIDIA nForce 630i, 7050 / NVIDIA nForce 610i, 7300 GT, 7800 GTX, 7100 GS, 7300 GS, 7300 SE / 7200 GS, 7800 SLI, 7900 GT/GTO, 7800 GS, 7500 LE, 7550 LE, 7150 / NVIDIA nForce 630i, 7900 GTX, 7025 / NVIDIA nForce 630a, 7350 LE, 7050 / NVIDIA nForce 630i, 7600 LE, 7950 GX2, 7900 GS, 7600 GT
GeForce 6 series:
6800 GT, 6100, 6800 Ultra, 6200 A-LE, 6800 XE, 6200 LE, 6700 XL, 6150, 6500, 6100 nForce 400, 6800 GS/XT, 6200 TurboCache, 6600 VE, 6200SE TurboCache, 6600 LE, 6200, 6800 GS, 6150LE / Quadro NVS 210S, 6100 nForce 405, 6600, 6100 nForce 420, 6600 GT, 6150SE nForce 430, 6150 LE, 6610 XL, 6800, 6250, 6800 LE, 6800 XT
ION series:
ION, ION LE
