New 257.21 WHQL NV drivers
About to install theese now, will give em a try on bfbc2. Running gtx 275's in sli, win 7 64.
setter I am thinking of going SLI(once I find a 790i mobo) what's the FPS increase with SLI over a single card.. 40% maybe?
thanks
So what's the verdict fermi owners? looks like there is no noticeable performance increase going by reports around the web, is that femi maxed out performance wise?
Was ATI's new cards maxed out after a couple of revisions of the drivers? is it maxed out now....
Is fermi maxed out now, who knows and who can say.
Only had a quick play with Heaven benchmark on a 470 - from the 257.15 beta to 257.21 WHQL there was a +0.875% increase in scores there :D I don't think its safe to say they are maxed out tho just yet - the 8800GT is still getting performance updates from the drivers even now.
I think it is a bit early to be calling that. Nvidia are still probably tuning compatibility and stability given the new architecture (how long did it take for ATI's fabled performance drivers to come out? 10.2/3 I believe?). Historically Nvidia have been very good at bringing performance increases to their products even a long time after launch.
Cheers mate
Just for record did you suffer from random black / flickering screens with last drivers ?
Not with the previous beta's i was using, though it did happen a few times on the 197.45 WHQL release
thanks
Heres a few quick benches i ran using FRAPS.
Single gtx 275.
Frames, Time (ms), Min, Max, Avg
19241, 341441, 30, 111, 56.352
Sli gtx 275's.
10693, 126977, 65, 123, 84.212
System is an i7 920 DO at 4ghz with 6gb of ram at 1547 mhz, 7-7-7-24, 1920x1200 all settings on high, 4 x aa, 8x af.
Anyone with a GTX280 on Vista or Win7 64-bit tried these out yet?
The last drivers 197.45 do randomly give me a screen flicker (goes black I think) in some games e.g. BF:BC2, so I'm thinking about giving these a whirl.
Works fine for me, although I never had a problem with older drivers either.
(GTX280 Win7 64bit)
Installed these and played BFBC2, I didnt seem to get any black screen flicker but its not often I get it so its still to early to tell, also didnt get a CTD between maps but again it doesnt always do it and I cant see that being a driver issue anyway but all in all looking good
Single gtx 275.
Sli gtx 275's.
Thanks for that ;)
I am now going to save for a XFX 790i Ultra mobo :)
No probs, with the single card bc2 was a bit jerky in places, since the addition of the second card it runs so much better now.:)
just thought i'd let you guys know, this new driver has totally fixed my BC2 map load times. cut down from about 3 mins to about 15 seconds! and the framerates have really improved in-game too.
excellent release :)
I'm still on 196.21's for my GTX 280, because of issues with the recent drivers. I guess it's time to update to these o_O
I have un-installed these drivers as I came out of a game and win 7 64bit asked
if I wanted to keep the color scheme I said yes and I got a black screen and then my monitor turned off.
I had to restart my computer. I tried again and the same happend. ...
I am installing over the top is everyone else doing this in Win 7?
Is it advisable still to completely remove old drivers theese days, ie uninstall, use driver cleaner. I used to do this when i was on xp, though ive never done this on win 7.
yeah not had any issues windows 7 x64
