Moved to BT
12 Oct 2008
Probably should have posted this first but its ordered and on its way.
Currently with talk talk and well... nothing more to say about them.
Just wanted to ask you guys some questions.
What do you think of BT, good support?, good internet speeds for your area?, if you had any problems with them.
What do you think of the BT Homehub? do you think i should upgrade to a better one?
i play a lot of online games and i download a lot using utorrents, do you think BT is good for these kind of tasks?
is it easy to open nat connection on BT?
I know that my d-link router and talk talk wont let me and i get pushed around when i ring them.
Thanks for your help, luke :D
What choices did you have? Look at Samknows.com.
Waiting for Rroff to come in and tell you off. :p
I'd recommend getting rid of the HomeHub but forwarding ports is easy on the Hub, however it is still a terrible router.
You still need a BT landline for BE/O2 but you will get a much much better service from either of them compared to BT
Yeah, if you download more than 100GB in a month you will be capped to (I think) half a meg from 5pm to 12pm (I think) something like that anyway...
will they offer more than 6meg in my area and what calls rates do they have?
Be* don't currently have a home phone service, but they are going to be releasing one very soon.
O2 on the otherhand do. Check their website...
Both Be* and O2 are currently the best ISP's in the UK...
