but the internet connection will run down the bt line and ive been told my line can only hold 6meg
If thats what BT have promised you, then o2/bethere will get at least that. They will be using the same line after all.
That's with ADSL Max...
LLU you'll most probably see double the speed.
Post your router stats.
Be* and O2 offer the best speeds all day, aswell as low pings and no FUP for torrenting...
I do believe that answers your questions?
LLU has nothing to do with speed. If BT have told him 6mbit connection on an ADSL2+ is what is expected, then I wouldn't expect much more.
why does it say bt is ADSL2+?
i play a lot of online games and i download a lot using utorrents,
BE What you'll need
* A BT phone line
* A device capable of communicating via TCP/IP (like a Windows PC, Mac, iPhone or Xbox with Live)
* A device with an Ethernet port for a wire connection to the BE Box
* An 802.11b or 802.11g compatible network adapter for wireless connection to the BE Box
* Windows 98SE / Mac OS 8.6 or higher
whats meant by a device with an Ethernet port for a wire connection to the BE Box.
do they supply you with a router / modem or do you have to buy one?
BE said i will be looking around 7meg in my area they 1meg more than bt. am i best of going with value because it offers 8meg and pro is 24meg but i will never get it so is it a waste of money?
