i recently stick a conventional flywheel and clutch on a 20vt a3. the main difference between the two was a slightly lighter clutch pedal. what issues have you had? ive heard a couple people say bad things about the valeo conversion now
My pedal isn't light, it's about the same as the DMF setup, not light, not heavy, in the middle lol.
Main annoyance is juddering in first when pulling off. If you slip the clutch quickly it's ok but if you're in traffic it's annoying.
It intermittently is a bit notchy on the old gearchange, yet sometimes is flawless and smooth. Weird.
Also it went from biting at the bottom of the pedal when new to now biting about 3/5ths up the pedal which is rather high in effect.
