They have the same ones on ebay for £40 - £20 less than m, there well worth the money.
I've been keeping my ebay eye on a few!
botbuilder.co.uk looks brilliant!
Flux is in the solder and stops (as long as you don't overcook the solder/join) dry joints being made:
http://en.wikipedia.org/wiki/Flux_(metallurgy)
I've honestly no idea. Stabbing wildly, maybe it's easier to control the heat on an electric?
Yeah I was going to say, now you can't buy lead solder, what's the alternative?Lead/Tin solder has a lower melting point, but is not allowed in consumer devices (Just look at RoHS). It is a lot easier to solder with, and much better to use. Just do not eat it. Buy a good quality solder, and no-clean flux.
On your point of flux, don't buy plumbing flux for electronics. It's different stuff, it's pretty noxious and it'll rot your circuit boards and soldering iron tip.
Variable heat isn't that important, odds are you won't use it as a beginner. You can get a few 20-30W Antex irons for under £10, great quality and easily good enough for pretty much everything.
