Hi
Basically step-son has been sick on his PC in his room, case was all shut etc, but some of it has got in to his case via air holes on the side panel i think.
Now it dont work and im not sure where to really start as iv not got any spare parts. The system powers up & the mother board lights comes on CPU fan spins but it hangs at the mother board splash screen where it says press delete for the bios press tab for the post screen.
PC specs.
Amd phenom 9850
2GB ram
Abit mother board ( cant remember, will post back if needed)
9800GT
USB keyboard which dont do anything, got some bringing a PS2 keyboard later to see if that will be able to get to the bios or not
Iv got 2 ideas at the mo either:
1, the m/board has packed up
2, the PSU got wet & for some reason is not giving another power now.
Using my system to write which is also i AMD setup. So i could spend ages trying to use my system as a test bad, which at this stage i dont want to do if it can be helped....But how safe is that, if some of his parts have shorted out or what ever. Would i run the risk of messing my system up?
So any advice on what is the problem could be, or am i right to think the m/board or PSU
Cheers
PC specs.
Amd phenom 9850
2GB ram
9800GT
Cheers
