I've recently rebuilt my pc with a couple of extra bits and pieces and just got my OC back to 3.4Ghz (although i suspect its not quite stable)
Started off with this, everything at stock and throttled in BIOS
then took GEST off
Under load at stock
Pushed things up to 3.4ghz
and under load
Did push the fans on my case up to full and the temps dropped a couple of degrees but thats neither here nor there.
So far I've run Intel Burn Test for 5 passes (although about to do more while the footy is on) along with an hour of Prime95 with nothing showing up. I have had this set up before and had it crashing on me hence the reason why I'm going to test things for longer.
Only thing I've really altered is the FSB and ratio for RAM / CPU. Core voltages left on auto (vcore showing as 1.2375 in BIOS 1.2 in cpuz dropping to 1.152v under load).
Unsure on how to get a higher clock (assuming that I've got 3.4 stable of course. Any advice?
then took GEST off
Under load at stock
and under load
) I guess you want to find a nice blend of CPU speed along with a decent FSB and Memory frequency . . . at the moment it seems you are UnderClocking the ram and running it at 533MHz instead of 666MHz
