Secondly, a few times after I got back and started it when it was warm (had been stopped for a few minutes each time), it started but died again straight away. A blip of the throttle before the revs drop and it's fine.
Likewise, the warm start thing doesnt seem to be uncommon - seems a lot of owners just accept it as "one of those things"
Depends if you consider juddering an adverse effect![]()
Just need to give it some more revs, but that's all part of the fun of driving a VTEC y0![]()
[TW]Fox;16788443 said:Quit the denial and get it fixed. A car that wont start properly is not 'one of those things' especially not on a Honda. It is broken and requires fixing.
[TW]Fox;16788443 said:It's hardly a positive effect![]()
[TW]Fox;16788443 said:It's not a Type R, the VTEC is there purely for extra economy not driving everywhere at 8000rpm going 'woohooo'.
They did say they pressure tested it but we'll see!
Was at my mates garage the other day and the topic of the a/c machine came up. Apparently the authorities are stepping up the regulations on it. It will become compulsory to not only do a vac test but a pressure test also. Apparently vac testing commonly fails to identify leaks. They will also be required to keep logs of exactly how much refrigerant has been recovered and charged into cars, and they will be subject to random inspections just like they are for MOTs.
[TW]Fox;16787747 said:Either way welcome to the world of older cars, where random repair bills become part of your monthly outgoings..
Did a bit of research and apparently replacing the clutch fluid normally cures a juddering clutch.
