21 Jun 2010 at 15:59 #1 Warmo161 Warmo161 Associate Joined 20 Jun 2010 Posts 69 Is this bundle ok? I am having thoughts that the case and the power supply might be wrong also, is the case suitable with my build??
21 Jun 2010 at 16:02 #2 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare PSU- http://www.overclockers.co.uk/showproduct.php?prodid=CA-118-AN&groupid=701&catid=123&subcat=1088 the western digital green isnt a fast harddrive, its good for storage. this is fast and has enough room- http://www.overclockers.co.uk/showproduct.php?prodid=HD-206-SE&groupid=701&catid=14&subcat=940
21 Jun 2010 at 16:02 #3 Gary* Gary* Associate Joined 11 Sep 2009 Posts 1,037 Case is fine, however the PSU you've chosen is pretty bad, get a branded one such as Corsair or OCZ. Anything around 400-500W will suffice.
21 Jun 2010 at 16:05 #4 wilko49 wilko49 Associate Joined 29 Mar 2010 Posts 831 agreed, change the HDD and PSU. The rest looks great.
21 Jun 2010 at 16:07 #5 Fallen god Fallen god Soldato Joined 4 Oct 2008 Posts 6,693 Location London I would maybe go with something like this, could add a heat sink and change the case if you wanted to.
21 Jun 2010 at 16:08 #6 Warmo161 Warmo161 Associate OP Joined 20 Jun 2010 Posts 69 ok, but the liquid cooling, will it come set up and attached to the motherboard if i get it?
21 Jun 2010 at 16:10 #7 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Warmo161 said: ok, but the liquid cooling, will it come set up and attached to the motherboard if i get it? Click to expand... dont think it does, ask the store when you order? but change that psu and harddrive
21 Jun 2010 at 16:12 #8 Warmo161 Warmo161 Associate OP Joined 20 Jun 2010 Posts 69 stulid said: dont think it does, ask the store when you order? but change that psu and harddrive Click to expand... it'll be a few months until i order anything, but i am getting intrested in building my own as it is better BTW: i changed the psu and hdd
21 Jun 2010 at 16:19 #9 Ryan-3 Ryan-3 Soldato Joined 14 Sep 2009 Posts 9,333 Location Northumberland I like the 1st, just put in the black version of that hdd, and the OCZ modXstream II 600w psu + I'm not an intel fanboy, for me, I only have intel as thats the only CPU brand that works!
21 Jun 2010 at 16:35 #10 Warmo161 Warmo161 Associate OP Joined 20 Jun 2010 Posts 69 ok, so i changed the power supply, and that will work fine with everything? including the overclock?
