go into documents folder under your name, go in to my documents, then BFBC2 folder and delete the settings file (the one at the bottom) it might fix it, you will just have to sort your resolution out after ingame.
ah cheers mate, all good and working
Playing through the campaign then will head onto multiplayer
The sound of the weapons are brilliant
EDIT: AH! Problems back, wont even start up now
Works fine when my second screen is disabled
