Hi, since I moved into my current house i've been having problems with voltage brownouts caused (I think) by the electric fences on a farm with which my house shares power. It was suggested to me that I buy an uninteruptable power supply, which I did. Problem is, I was under the mistaken opinion that the battery in the ups charged while giving power output to the equipment. Turns out that it doesn't, the battery only kicks in when the power dies. I probably should have thought more into it before buying it, but I didn't. My question is, where to stand on the basis of a refund?, is it possible to get a refund just because I made the mistake of thinking that the device does something that it doesn't. (didn't buy it from overclockers so no conflict)
Also, do you guys have any other ideas as to how to solve my brownout problem?. It does not effect the working of my equipment but it does cause a worrying ticking noise every few seconds from the electronics, the tick is louder with higher wattage equipment.
thanks.
thanks.
