Math help... Massively stupid here :(
1 Dec 2006
Amsterdam, NL
I can't type it as some of the characters are hard to find.
I am confused at how to display both the answer and how I worked it out!
what does the -# mean after the number? How do I work it out?
Beyond confused at the moment :( Anyone who is great at math please let me know if you are free via msn or something, could use some help.
Any help would be greatly appreciated, I know this is basic stuff but unfortunately math was one of my very weak points throughout school and I NEED to bring it back up to speed.
ags
There indicies, basically meaning the number times itself that many times. So 10^5 (that's how it's written) would be 10x10x10x10x10, which is equal to 100000. The format you see in the question above is called standard form, which is a way of showing very large and small numbers easily. So 7.23 x 10^5 is 7.23 x 100000, which is 723000.
Hope this helps you see where to go.
Great, that clarifies that part, cheers mate, but what about the 10^-3???
I have no idea how that comes into play? Does it reverse it's self into the decimal places? so 10x10x10 (from -3) being 0.010?
ags
10^-1 = 1/10^1
10^-2 = 1/10^2
etc etc
You can do these questions very easily on a calculator by using the E button.
7.23E5 = 7.23 x 10^5
Ah sorry, forgot that bit. The minus just means that it is the inverse (1 over the answer). So 3^-1 would be 1/3, and in your case 10^-3 is 1/(10^3), which is 1/1000.
ags
Yep. 10^-3 is essentially 1/10^3, so the answer is actually 0.001. If it's powers of ten, it's easy to remember, it's simply the number of 0's before/after the one.
Oh, and whenever you multiply/divide powers of the same number, they cancel out which makes them easy, for example, take your above equation:
(7.23 * 10^5 * 1.09 * 10^-3) / (8.97 * 10^-4)
This equation can be rearranged/simplified to 7.23 * 1.09 * 10^5 x 10^-3 / 10^-4 / 8.97
When you multiply 10^5 and 10^-3 together, you simply add the powers, so 5 add -3 is 2, so 10^5 x 10^-3 is 10^2.
When you divide powers, you just subtract the powers, so 10^2 / 10^-4 is 10^6, because 2 minus -4 is 6.
So the final equation simplifies to 7.23 * 1.09 / 8.97 x 10^6
If you calculate 7.23 * 1.09 / 8.97, you get 0.879 (3 d.p)
0.879 x 10^6 is the same as 8.79 x 10^5, so there you go.
Brilliant, can anyone show how the paper has come to the get the equation at the bottom which 'should' be the answer?
If I understand correctly, I should be getting this then.
788.07
0.000897
I have a feeling I am going wrong somewhere lol
ags
788.07
0.000897
ags
Just edited my above post to show how I worked it out. Your answer is technically correct, if you calculate that, you get 878,561.87
8.79 x 10^5 is 879,000 (essentially 878,561 rounded)
To convert a number into standard form, just multiply or divide the number by a power of 10 so that you have just one number in front of the decimal point - e.g:
878,561.87 / 100,000 = 8.7856187
100,000 is 10^5, round your 8.7856187 to 8.79, and you have 8.79 * 10^5
Brilliant, I have the hang of it!
Thank you so much, means a lot :D
Expect more dumb ass questions soon lol.
ags
