Translation is not the best, but we get a general idea
List of changes with new firmware:
1. Increase the transition fade animation is harmonious and systems with well.
2. The acceleration of the system, such as the original come out if there are two menus, such as to select the input method menu, this time to pull down the notification bar will feel very card, obviously rom optimization problems, now resolved.
3.ui on some changes, mainly in the ts ms. Ts a theme options, and also that can change the ts background, but only a few basic application is built-in color change. Speed did not feel a raise, ts is the same card to do home.
Mediascape ui have some changes, mainly under the three options have changed, and then press the menu button to enter the video there will be three options, one more zoom options, double scale, was canceled. Adjust the volume of ui also looking from another, and the overall sense of the whole system more.
4. AV sync problem-solving.Some films turn themselves in before the point of view clear rom video are not synchronized, but in this rom no problem at all!
5. There is also a very important, and each brush must try a firmware software is skyfire. Firmware before using this software will have problems, buffering the window has been blocked playback screen will be, but this firmware to solve this problem! This software can be a temporary alternative to flash video.
its already loads faster than any other phone cam ive used
