Hi guys,
I'm in the process of building a new gaming rig, but I can't really decide which case would suit me the best. I really appreciate advices from experienced overclockers/gamers around here.
My system will be like this:
Things I'll probably do in the future: (after replacing PSU possibly)
1. 5870 CrossFire, or swap with new Radeon (I expect them to be longer in length)
2. OC both CPU/GPU if needed
I know it's a very difficult request, but I want my case to;
1. have very good air cooling ability (might swap H50 with NH-D14 or something)
2. be as quiet as possible idle/load
3. have removable dust filters for fans/PSU
If possible, I would like my case to;
4. be as light as possible, say, ~10kg would be very nice but I don't mind ~15kg
5. cost less than £200...although I don't mind paying extra if required but £250 is the limit.
so basically something that is not a jet engine and does not require a forklift to carry it around.
I've been reading reviews and going to shops to see the cases myself, and I narrowed my choices to the following cases, and I added the reasons for not getting them.
CM Storm Sniper (not sure about the noise+misses dust filter for PSU)
CM COSMOS (not sure about cooling ability)
CM 690 II Advanced (not sure about the noise)
Antec P183 (not sure about the space for graphics card and cooling ability)
Fractal Design Define R2 (not sure about the space for graphics card)
SilverStone FT-01 or FT-02 (FT-01: not really removable dust filter at the top? FT-02: relatively expensive and heavier compared to the others)
I'm slightly tempted to get CM 690 II, and replace all the fans with Noctua ones, but I'm open to alternatives, especially Lian Li cases, as long as they meet the criteria. I know water cooling would solve probably all of the noise/cooling issues I mentioned, but I'm not too keen on that unfortunately...
So what do you guys think?
Should I stop dreaming about getting a mid-tower case that satisfies all my needs and get a full tower like Lian Li A70/ CM ATCS 840/ SS FT-02?
