Hey, Spec me a rig for less than £650
ati4670 is to slow for that res.
its very occasional, I was playing COD4 at a local Internet Cafe type thing at 1440x900 on a 7900GT. And it was playable, and it never bothered me, as long as its consistent and >45-60 frames even with a few settings off.
  • on my quest for the perfect parts list xD
  • mainly be used for college, Photoshop, Fireworks, dreamweaver, flash and after effects.
  • I would like to play occasional cod4 pc maybe even mw2
  • will be playing at 1920x1080 (monitor/Tv)
  • don't need a blu ray drive.
  • budget will be around £650 might be able to stretch to £750
  • I love the look and reviews of the antec 300
  • this is to last me a good few years
  • not exactly earning mega money
  • upgradeability would be a huge plus
I like the look of the top i3 one :D
this is to last me a good few years not exactly earning mega money so upgradeability would be a huge plus.
£20 difference and just oozing "upgradeability" . . . . Allows Crossfire in the future . . it allows an easy CPU upgrade in the future (if you needed a Hex core in a 12-18months say) . . . It's the same build as #2 above but just with a HD 5770 instead of the HD 5830! :)
Oh forgot to say USB 3.0 and SATA III as standard if thats important to your future needs?
Do you do any really data intensive stuff aside from gaming? maybe in the next 6 months to 12 months maybe? . . . . Four Actual cores outperforms two HyperThreaded Cores in really CPU intensive applications . . .
Off Topic:
Can you try and avoid quoting a post containing huge images please Ross . . . It's not such a biggy for this spec-me-thread but if you do that in other peoples threads it won't go down well . . . can you click [Edit] on post #24 and delete the 3000 pixel high image pretty please!
Last one from me Ross . . . I can tell your not sure about your GPU yet so here are the three base builds from above (minus Core i5) with just onboard graphics! :) . . . They are all good but the two AM3 build offer a better long term investment I feel . . . It's quite a decent budget you have so take a little while sussing out the pro's and con's of each system and spend with confidence! :cool:
ASUS P7H55-M
Gigabyte GA-890GPA-UD3H
thanks, how do i remove pictures from posts? not familiar with vbulletin all that much, since i only use one other forum thats been swapped to ipboard for a while and now back to vbulletin lol and the official xbox forums.
Use the backspace?
Remove the IMG tags, or part of them. If it just shows the picture, backspace is your friend.
Erm, would a nVidia card not be better for photoshop etc?
Thinking in terms of CUDA and PhysX
I think some Adobe Applications Support CUDA although apparently it dosnt make a lot of difference?, but i thought PhysX was just for games?
Hey Cookeh! :)
I didn't include a GPU in the specs from post #27 . . . thought that would be best worked out in the GPU Subforum
Just for the record I use Photoshop daily and the acceleration feature works fine with either ATI or nVidia cards! :cool:
  • Intel® Core™ i3 530 - £543.80
  • AMD® Athlon™ II X4 635 - £563.00
  • AMD® Phenom™ II X4 955 - £618.80
Physx is a game thing, but the nvidia gpu cores are made up of individual CUDA processors, programs can use the massive power of these to speed up rendering and processing, the difference between a cpu and a gpu is massive!!!!!!!
the above videos are using the workstation/professional Quadro gpus, but the results are similar
So then would a GTS240 or may GTS250 depending on offer, be better for my needs than a ATI card? with an i3 530?
you want to play some games, so ignore the 240, the 250 is good(but really its just a re-named 9800gtx) depends on the price of the 250?
If you can find a 260/275GTX then they are brilliant and bare no resemblance to the 250, they are a completely different gpu architecture
Dosnt the GTS240 come in some Alienwares and Dell "Games PC's" Even though im thinking, since i have PS3 and 360, whether Games on PC would really be worth the extra money atm?
Dell=dull
completely your choice of if you want to use your console or buy a graphics card that can cope with some decent gaming
http://www.overclockers.co.uk/showproduct.php?prodid=GX-025-PV&groupid=701&catid=56&subcat=1009
not bad for the cash, for CUDA support it has to be a Nvidia 9*** series or newer
Dell=dull
completely your choice of graphics card,
Since a GTS250 is a rebranded 9800GT, does that mean i could expect similar frame rates? Or at least relatively acceptable frame rates if i changed my mind? I have a friend who has a 9800GT in his machine, and he can play games perfectly fine, but mainly uses his machine for Dreamweaver and Photoshop.
Just dont want to spend too much since Being 17, and jobs that are available all offer minimum wage lol
Hey Ross,
can I get a bit of user feedback from you please? . . . I'm curious to know what you find appealing about the Intel® Core™ i3? . . . particularly since you stated "upgradeability would be a huge plus"?
Are you just more comfy with Intel® products and are not sure about AMD® or?
Thanks in advance for your insights! ;)
