- 17 Mar 2004
Boost gauge
ok so,
3) Decompression plate (where does this go?)
4) Another headgasget (for what exactly?)
If you state the car in question, we can help you out more !
An engine designed for use as NASP will have the wrong compression ratio to run with forced induction.
Would the engine bay of a ZS180 even have room for a turbo?
There's no such thing as the 'wrong' compression ratio, the compression ratio only to some effect limits the amount of boost you can run
You can still build a high compression engine and run high amounts of boost - people running really low CR's to get high boost are usually only doing so because they don't have a precise enough system, or the ability, to control fuelling and air temperature enough to keep the engine together.
There's also another tradeoff there - running a low CR engine and high boost sometimes can produce less power than a similar engine with a higher CR and less boost - and the one with higher CR will be considerably more snappy and lively.
I mean, the original 'Jetfire' turbocharged V8 ran a 10:1 compression ratio. The newer Skyline still runs 9:1 too.
Most factory engines, with factory bits, will take 5-8PSI without complaining, provided you can control fuel, ignition and intake temperature well enough![]()
