Hi Folks,
Could you help a newbie putting together 1st MicroATX build please?
So far I have all the kits/parts ready but have been reading for the last few hours on how to put them together so basically trying to know which cables go where etc ... before I start putting them together.
Also been reading Greywolf system build guide which is very helpful ...
http://forums.overclockers.co.uk/showthread.php?t=18046396
Basic specs:
1) Lian Li V351
2) Gigabyte GA-P55M-UD2
3) Corsair H50 cooling.
4) Antec TruePower 550 modular.
My full system spec in detail here:
http://forums.overclockers.co.uk/showthread.php?t=18157157&page=2
Question:
1) Where do I get so many fans connections? i.e. one for stock case fan, one for HD fans and one for Corsair H50 radiator fan?
On the mobo there are CPU_FAN and SYS_FAN only so how do you hook up so many fans?
2) Where does the H50 3-pin pump connect to for my set up? I just cannot find any 3-pin connector at all. This H50 pump need to connect to constant power source unlike fan as explained by Corsair H50 on Youtube.
Helllllpppp pleeeeasseee!
Cheers
p/s: I will start with this two questions first.
Basic specs:
1) Lian Li V351
Question:
Cheers
