Inwin dragon slayer. remember that tiny case posted here a few months back, its that!
Yeah, it's too clearly scripted. It can be useful but essentially all he does is read out the spec sheet. The only thing about them that i actually use is the sound examples.
I think the case looks terrible.
But on the other hand it looks like a case I'd like to mod.
The internal layout is nice but I'd:
Change both sides to solid panels, probably including deadening material. As well as anywhere else it can be installed.
Remove all ridges/badge/mesh on the front to leave just a radius at the corners to frame the front.
Redo the front with the same hex mesh but in a single piece cover from below the power button to the base.
Alternatively. Scrap the entire original bezel and redo it from scratch as above.
Have the front hinge off sideways with fasteners hidden under side panels for dust filter cleaning. Dust filters will be on the case side not the door itself.
Redo the back to remove watercooling holes, add another 90mm fan...
I can see modding costing far more than the case o.0
Actually gonna do a partial upgrade now, ive decided, ready for i40 :)
So the sooner OcUK gets this in with a Rampage III Gene the better for both of us :D
