Car transport & wheel alignment
NVP
NVP
6 Sep 2007
Can car transport trucks affect wheel alignment?
If your car is attached to either a flat bed or a truck (or whatever is typically used to transport cars) would the way the car is secured affect the wheel alignment?
Hardly worthy of a new thread but I didn't know where else to put it.
I was mainly concerned with the momentum of the truck causing jolting and/or movements which wouldn't happen from everyday driving but thanks, that's slightly reassuring. :)
No.
All cars are strapped in the same way these days using the wheel straps, i even have a set for my car trailer. The AA, RAC etc all use them too. Never heard of a single problem with them, cant image it would go unreported if it did cause problems.
Nah I'm not talking about BIG problems, just minor alignment issues. I just spent some wedge at BMW for them to do a "proper" KDS alignment so don't want it to all be a waste.
The load your suspension is subject just going around a corner will be bigger than going on a car transporter. The only load you are putting into the car is in the direction the suspension is designed to absorb
I'll be bold and say the alignment will just be 'within tollerance' and as such any such minor movement would make no difference.
Thanks bro, I am once again feeling reassured :) ... until someone else comes in to tell me it's possible lol
If he tied the straps around the steering arms then it could bend them and put your tracking out.
he would have to be a moron to do that though ;)
Take a picture of the car from some distance afterwards, post up here and someone will be able to tell you if your wheel alignment is okay or not :D
