CPU Temp advice on new pre built.
  • Thread starter Thread starter Jup
  • Start date Start date
Something is going wrong here. You either have the system in a sauna or the CPU cooler is being dislodged. I'm going with the latter. Send me an email and I can get your system sorted out for you.
The Venom cooler should not be reaching 90C. The only thing I can suggest at this moment in time is to go inside the case and feel if the cooler is getting hot, if it is fairly cool then it is not mounting correctly.
Hi NathWraith, The cooler installed is a Titan Fenrir and the fins are in no way hot, not even warm. How can I get your email mate?
Thanks for the help.
Jup
