Out of interest how much power does an AC unit draw? Must be relatively expensive to cool a whole room I'd have thought
As to how much power it draws, the absolute maximum current I've ever registered my unit drawing is 5.5 amps.
P=IV so power = 5.5 x 240
Absolute max Power draw = 1.32 kW
Since that's when it's providing about 4kW of heat, you'd actually be getting a bargain there, but tbh i never need that amount of heating... It would top 30c in winter in no time.
Cooling: With a small modern split system like mine, to cool the whole room (17 foot by 10 foot) once (from say, 25c, down to 18c) takes about half an hour and during that time the unit draws about 800 watts for half an hour (0.4kWh).
Last time I checked we pay 11.5pence per kilowatt-hour for electricity... - so the cost to "cool a whole room" once would be about 4 and a half pence (or 5 cents if you use euros).
In general use I just set it to maintain a temp of 18c and leave it... and even on the hottest days it only sips 8 pence per hour, which in my opinion is well worth it for the joy of having a truly cool place to chill out. Of course if I fancy doing a spot of extreme overclocking I set it to 14c - since the unit is more powerful than the room needs, even in summer the temp in the room drops to 11c, and the temp of air coming out of the vents actually drops below zero...
All I need to do now is fit my computer on a bracket in front of the vents.
