I've had this case for a while now but have only just come to use the front headphones port.
Not only is it a very dodgey fit for a headphone jack (very stiff and needs a shove to get it in else it'll pop out) but also the sound has a very annoying hiss in the background - and to make matters worse I can hear a whurring noise in the phones when the disc spins!
I have checked the wiring inside the case and the HD Audio is plugged onto the correct pins on the Mobo and it's all fine (no loose wires etc).
Is this a common problem with this case or do I just happen to have a dud?
In which case it's probably too late for RMA and I'll have to live with it -_- or find some sort of extension to plug it into the rear port (Very annoying!)
). I usually plug my headphones into the 3.5mm jack in my speakers though.
