It's not the problem with the GTX480...it's the Q6600 not being fast enough running single/dual thread.
People that say Q6600 at 3.0GHz is not a problem with WOW...have you actually used one to play the game?
Most mmorpg is either single or dual-threaded, so a faster dual-core would deliver better frame rate than a slower Quad core.
There's a mmorpg I'm playing (not WOW) which my minimum frame rate would drop to 15fps at 1024x168 when there are many players on screen, even though my GPU usage is only around 20% max. I have a friend who got a Phenom II 965BE at stock speed 3.4GHz and with a 5850 playing the same game as me, and his minium frame rate is also lower than 20fps.
This is why i5 750 or i7 920 overclocked to around 4.0GHz will deliver higher frame rate in most mmorpg, because they are the fastest running single or dual-thread operation.
mmorpgs are always tend to be more CPU dependent than GPU.
Sorry Robert, I was refering to those that say Q6600 at 3.0GHz would not a limiting factor for WOW.Yes I have.
I think you friends should probably have a check at the graphic settings he's running the game at.
15-40fp with a GTX480...it should be quite logical to assume the CPU is bottlenecking the graphic card. And yes disabling shadow could help in mmorpgs.
I don't think it's just WOW alone, but most mmorpgs in general would have similiar problems.WoW is just a badly optimised game, the shadows even more so.
It could be something else - for example addons.
I was running an addon which became out of date in a patch, and then literally every pull after an enemy died my FPS dropped to like 2 or something. Disabled the addon, and guess what? It went back to normals.
hopefully you wont have to wait as long.A quad 3ghz is perfectly ample.
He shouldn't be getting performance like that.
my old E5200 @ 3.7Ghz gave me the same performance on mw2 as my i7 @ 4Ghz but warcraft being such a CPU intensive game i saw triple the frame rate because of the CPU thats how CPU intensive WOW is it's a very old game engine sadly.
People saying the Q6600 is killing his syetm are just plane wrong, it's still a great cpu and fast enough for todays games.
