CORSAIR XMS3 6GB DDR3 12800 CAS 9 (1600MHz) TRI-CHANNEL KITS DOWN IN PRICE
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel (CMX6GX3M3A1600C9) @ £132.99 inc VAT
The XMS Series CMX6GX3M3A1600C9 is a 6144MByte kit of DDR3 SDRAM DIMMs built using Corsair’s high performance heat sink which includes Intel’s Extreme Memory Profiles (XMP 1.2). This part delivers outstanding performance in the latest generation of X58 DDR3-based motherboards. It has been tested extensively in popular X58 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1600MHz at latencies of 9-9-9-24 at 1.65V VDIMM.
- Each three module set is tested at 1600MHz
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.65V, at latency settings of 9-9-9-24 on Intel X58 DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.65V
- 6144 Megabytes of DDR3 memory
- Three matched 2GB modules
- 100% tested at 1600MHz in X58-based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
Only £132.99 inc VAT.
ORDER NOW
For anyone who is wondering I have just read up that this has a better Heat Spreader than the similar TR3X6G1600C9, and it's now cheaper too :)
glad ive got these RAM then .. =) ..although...mine seems to be a different colour...the colour is white...and not blue =/ does that make a difference?
