Budjet PC £500 (Build Advice)
28 Jun 2010
Hello
I am looking for some advice for components to build a PC with a budjet of £500 so i decided to come to the experts.
Here are some criteria that i want to build to fit:
Quiet running
Plays Games at high graffics setting and resolution (on 1440 x 900 or 1680x 1050)
Will last atleast 3 years
Is able to have graffics card upgrades in the future
(i do not really want to overclock)
I will be useing the PC for 3D moddeling and Hard core gaming.
Things i need: All components and Case, I am not to fused about the case so a cheap one will do. (i do not need a monitor)
If you need anymore info please just ask. Thank you for reading and i hope you can help me!! :)
at that resolution a 5770 is a little weak, so went for a 5830, i presume you have a copy of windows.
Your basketProduct Name Qty Price Line Total
Sapphire ATI Radeon HD 5830 1024MB GDDR5 PCI-Express Graphics Card £163.99
(£139.57) £163.99
(£139.57)
Asus M4A79XTD Evo (Socket AM3) DDR3 Motherboard £89.99
(£76.59) £89.99
(£76.59)
Patriot G Series 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel (PGS34G1333ELK) £88.99
(£75.74) £88.99
(£75.74)
AMD Athlon II X4 Quad Core 635 2.90GHz (Socket AM3) - Retail £80.99
(£68.93) £80.99
(£68.93)
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £39.99
(£34.03) £39.99
(£34.03)
Corsair CX 400W ATX Power Supply (CMPSU-400CXUK) £38.99
(£33.18) £38.99
(£33.18)
Xigmatek Asgard Midi Tower Case - Black £26.99
(£22.97) £26.99
(£22.97)
Sub Total : £451.01
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 17.50% VAT : £80.98
Total : £543.74
The motherboard does crossfire so graphics u[grades will be as easy as buying a second card and poping it in
5770 isn't that bad at 1680x 1050...
I've put a bit more emphasis on this being quiet:
If you go with the 5830 that Stulid suggested, this: OCZ 500W ModXStream is really the cheapest PSU you should use as the Corsair CX400W only has 1 PCIE connector.
5770 isnt strong enough at 1680X1050.
it was all in last months custom pc, as to which card to have at which resolution.
Difficult to fit a £164 card in a £500 budget for a 'quiet' PC though.
I did it, with a crossfire capable motherboard too, none of this M-ATX rubbish.
the psu is quiet and the case is cool and quiet, just the stock amd cooler is a bit load sometimes, a few weeks later buy a cooler, no biggie
The motherboard does crossfire so graphics upgrades will be as easy as buying a second card and poping it in
No, you didn't. The PSU doesn't have enough connectors for one 5830, let alone 2.
Would you really run crossfire 5830s using 3 molex adaptors? I wouldn't risk that in my system.
