- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Corsair Obsidian 700D Full Tower Case & Corsair HX 620W ATX Modular SLI Compliant Power Supply @ £199.99 inc VAT
The steel structure has a matte black coating both inside out and is finished with a brushed aluminum faceplate for a professional look that’s both serious and awe-inspiring.
The power supply compartment, main compartment and the SATA bays each have dedicated cooling subsystems to prevent heat buildup.
A dust-filtered 140mm fan draws in cold air at the bottom of the chassis and exhausts it at the rear and top. This clever design forces fresh air directly over the graphics card and CPU. The hard drive / SSD bays are cooled by a separate 140mm fan which vents from the chassis via a sealed chamber and prevents the heat generated by the drives from entering the main compartment. The power supply compartment has its own dedicated intake and exhaust, also isolated from the main compartment.
Need even more cooling performance? The Obsidian Series 700D has pre-drilled support for top-mounted single, dual, and triple radiators, or up to three additional 120mm fans.
Advanced Features for Extreme Flexibility.
Six drive bays with clever snap-in trays accommodate both 3.5” and 2.5” drives with no adapter necessary. A unique cable routing system virtually eliminates cable clutter that can impede airflow. The tool-free design allows for easy entry, easy access, and quick installation of 5.25” drives.
- Six HDD / SSD drive bays compatible with both 3.5” and 2.5” drives
- Removable CPU backplate panel for easy heatsink installation
- Isolated cooling zones prevent heat buildup
- Unique cable routing holes guarantee a clean and clutter-free installation
- Three fans included, with the ability to add four more 120mm fans
- Tool-free optical drive installation makes building a system faster than ever
- Two year warranty with Corsair’s world-class customer service and technical support
- Dimensions: (609mm X 609mm X 229 mm)
- 5 x 5.25" Drive Bays
- 6 x 3.5" or 2.5" Drive Bays
- Front I/O: 4 x USB2.0, 1 x FireWire, 2 x Audio
From the manufacturer of the "World's Most Awarded Memory" comes the Corsair HX Series Power Supply. With that same legendary focus on the performance and reliability, Corsair has engineered the HX Series to support even the most demanding of systems. The Corsair HX Series incorporates the most advanced technology to deliver reliable, continuous, and efficient power to all critical system components. The HX Series is the ideal power supply for high performance and gaming PCs, Audio/Video workstations, and file servers.
- Supports the latest ATX12V v2.2 and EPS12V 2.91 standards and is backwards compatible.
- Guaranteed compatibility with dual-GPU configurations.
- Double forward switching circuitry design offers high efficiency, up to 80% under wide load range.
- Active Power Factor Correction with PF value=0.99 provides clean and reliable power to your system.
- Universal AC input 90~264V automatically scans and detects the correct voltage. No more hassle of flipping that tiny red switch!
- Ultra quiet 120mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying the RPM in response to temperature.
- Guaranteed to deliver rated specifications at 50ºC.
- Triple 12V Rails provide independent reliable power to the CPU, video card and other components with a combined rating of 50A (40A on 520W) maximum! Advanced circuitry design that automatically enables power sharing between the triple +12V rails in an event of overload on any single +12V rail.
- Powerful +5Vsb rail with 3A rating.
- Over Current/Voltage/Power Protection, Under Voltage Protection, and Short Circuit Protection provide maximum safety for your critical system components.
- 105ºC rated industrial grade capacitors provide uncompromised performance and reliability, delivering 4 times the lifespan of conventional 85ºC rated capacitors.
- Enhanced modular flexible cables enable easier cable routing and increased airflow in the system.
- Gold Plated connectors provide oxide free ultra low-resistance contact between the power supply and your critical components.
- 8 Serial ATA connectors (4 on 520W).
- Dimension: 5.9"(W) x 3.4"(H) X 5.9"(L) 150mm(W) x 86mm(H) x 150mm(L)
- MTBF: 100,000 Hours
Only £199.99 inc VAT.
ORDER NOW
ORDER NOW
so we'll see what they say tomorrow.
