Hi, just wondering if anyone knows what size the stock fan is on the Phenom 2 processor/heatsink. It's the one that snaps into the black plastic frame. I'd measure it myself but I'm not sure if they are measured by the frame size or the fan diameter.
Also can anyone recommend a decent , quiet replacement until I get watercooling ?, the stock fan has an unbearable whine even with q-fan enabled. Just a decent replacement fan will do, I dont really want an entire new aircooler unit as I'm getting a h50 or coolit eco asap.
Cheers
Cheers
