Ah **** quoted the wrong link. Was meant to quote the Crysis test:
http://www.bit-tech.net/hardware/cpus/2010/03/01/intel-core-i7-930-cpu-review/7
and I repeat, wheres it say 42 minimum?
It was from a X58 motherboard lab-test by bit-tech. It's not shown in the link you posted, sorry that I didn't make it clearer.and I repeat, wheres it say 42 minimum?
The minimum 42fps result was for i7 with Gigabyte GA-X58A-UD3R with a 5870.
http://www.bit-tech.net/hardware/cpus/2010/03/11/intel-core-i7-980x-extreme-edition-review/8[/URL]
which is higher than that crysis link, which has the i5 750 just 2fps slower than the 920/930 at 4.15/4.08/4.3ghz respectively, the results cant be compared between the two different reviews
blah blah
I quoted the link to the X3: Terran Conflict instead of the link to the Crysis from by mistake because both were in the same post, and I corrected the link from X3 back to Crysis that's all.you then sprout some rubbish about 42fps minimum, which I ask for where? you finally provide a link, to a different review with diffewrent overclock settings.
and you have gone back and edited your posts, to make them look less FAIL.
