- 11 Sep 2008
Just turned my speakers on via the plug...Computer turned of. I tried to turn it back on, and it wouldn't...So i plugged it out of the wall and back in, and it booted...This is very odd.
Hey there, I don't think it's a power issue but its always good to make sure. Since soon after release, I have been running the 5850 and an overclocked q6600 on a coolermaster 460 with 2x18a 12v rails. What board is it you have?
i had same problem with my old Gigabyte GA-MA790FXT-UD5P board. everytime i turn a wall plug on even in a different room,,, the system would reboot by it self.Just turned my speakers on via the plug...Computer turned of. I tried to turn it back on, and it wouldn't...So i plugged it out of the wall and back in, and it booted...This is very odd.
Motherboard is an Asus P5KPL AM
If it works fine with your 4850 but not the 5850 then it's not the psu, and that psu should be fine to power the 5850. I havent updated my sig yet as I have a new psu but remove the 9600GT and all of that ran fine on the 500W psu.
So it's either a duff 5850 or an incompatibility, remove all the cards you can except the 5850, if it still happens it's a duff 5850 or it's incompatible with your m/b
I suggested you updated your m/b bios to latest, has this been done yet?
What do you mean by remove all cards except the 5850?
Also, where do i update my Bios? When i go to the Asus site and have a look, there's lots of updates...Do i just download them all?
Ok just got the Bios update. It's just a ROM file, what do i do with it? (Sorry to be a noob) Also, i will try that Meatloaf.
Cheers. I contacted OCUK, and they say...
Are you sure you are not overloading the PSU? 600W is not that powerful to be running a 5850?
Regards,
