There is a VTEC for all needs really! Amazingly the performance on all of them is fairly similar.
If you want a hardcore track machine you have the Integra DC2/5
If you need a bit more space then you have the EP3.
If you are on a budget then you have the earlier Civic VTi/VTis (3 door hatchs, 5 door hatches, saloons and the Aerodeck)
Want a bigger car with more space then there is the Accord Type R
[bias] or if you want cheap, comfy and fairly quick then there is the various Preludes [/bias]
I'm not sure about the newer Accords - I think they are really smart but did they make a full fat VTEC one (i.e not the economy VTEC)?
I had one of those manual imports LSD VTEC BB4 rare (apparently) Preludes and it was great.
Pic here. I would have another one as they are exceedingly cheap now but trying to find a good one would be tough! A later model may be better.
EDIT - don't forget the CR-Xs as well! The original coupes are really sought after and the convertibles would be good in this weather - depending on the roof mech!
