No it shouldn't... It's UPTO 20Mb.
Around what times would I expect to get 20MB Speeds then? Just seems like a marketing ploy to me.
You will most probably never see 20Mb on that connection.
ADSL speeds are dependent on the quality of the line, and distance to the exchange.
Only the lucky few get 20+Mb on their line.
Post your connection stats.
That's the problem..I don't trust you! In this country some people only have BT as their option like me.
Thats not true. With a line attenuation of 12.7db you should be hitting 20mbps. My cousin has a 29db and hit 17, a friend has 23 and hits 21mbps. Both on sky.
Have you tried with the router plugged into the test socket? Removed the ring wire?
Thanks for the reply guys.
My HH isn't connected to the main socket in my house, I actually have a few questions about that -
In my parents room, there is a phone socket, so I run an extension box from there room into my room, and then plug the microfilter and other connections into the extension box.
Would I possibly get a faster connection speed if I was to run it directly from the main socket I have downstairs?
Cheers
Yes.
Just do the test socket and check the ring wires.
http://www.adsl2forum.co.uk/showthread.php?t=8152
