Hi everyone,
I have a Zalman600-HP powering my current system, which bought from OC in May 09. About 6 months ago my system began behaving strangely - every now and then it wouldn't boot up. The case fans etc would spin up, the motherboard lights would come on, but nothing came through my display and as far as I could tell the system didn't reach BIOS. On listening closer, I also noticed that the fans on my GTX260 didn't spin up either.
I'd have to power off then on again a few times before I'd get a 'good one' and my system powered up and ran as normal. No error messages, no difference in performance or anything.
This behaviour got more and more common, until now it's maybe 80% of the time when the system wont boot. I swapped in a cheap wee PSU to test it, and sure enough the system ran smoothly 100% of the time. I RMA'd the Zalman to Overclockers under warranty who tested it, said it was fine, and sent it back with the bill for testing. That was in January this year. I've been running on a back-up PSU since, but it's just not cutting it. So this week I swapped the Zalman back in, and sure enough the same behaviour has started. Took me 20 goes to get the system to boot today.
Can anyone think of why this might be happening? I don't want to RMA the Zalman again just to be charged the technicians fee and have it sent right back. Could there be some reason, some BIOS setting or something, that's causing this? My own theory is that a surge of power is needed at post to power up the GTX260, and maybe the Zalman isn't delivering it, but afterwards the rails are all fine. But then why does the cheap-ass 500w non-brand PSU I swapped in have no difficulties with this? Is it possible then when testing my Zalman the technician only tested the stability of the rails (which would be fine) and missed something that happens right at boot?
Many thanks in advance for any theories, no matter how wild!
My spec:
Intel Core 2 6600
Asus P5B Deluxe
Corsair 2GB 6400 dual channel DDR2
Sparkle Geforce GTX260
Soundblaster Audigy LS
Zalman600-HP
Stock coolers, nothing fancy or unusual
No overclock
Windows XP sp3
My spec:
Intel Core 2 6600
Asus P5B Deluxe
Zalman600-HP
No overclock
Windows XP sp3
