Which Blackberry?
14 Apr 2010
Fancy a Blackberry but not sure which one. Thing is, i am PYG and can't afford the 9700.
Under £200 is what i have to spend. Any help would be great. Thanks
I've been thinking about one of these myself since they are 150 now although you have to get a 20 quid sim pack with it.
What's the BlackBerry® Curve™ 8520 like in use, Any good ?
8520 is a very good entry level Blackberry, the trackpad is by far better than the ball on the previous berrys, the 8900 curve is a very good phone, better screen resolution than the 8520, should pick one up for £150 or there abouts, I use a 9700 now and its a cracking piece of kit
I like the curve. Dont like touch screen so i'm happy with the trackball as I don't have to wipe my greasy paws all over the screen. Updated the OS to 5.
Edit: I might add I payed £120.00 for mine (8900) second hand.
Blackberry Curve 8900.
Is that a good buy?
Well it was for me :) The dealer I purchased from was off the bay-but a quick search will reveal some grade B models with 90 day warranty for about £120 if that means anything to you).
Is the 8900 a good buy at £150?
For me it would have to be spotless at that price: from a UK seller and offer some kind of a warranty. Is it from a private seller by any chance or from a shop?
Edit: It would be interesting to see what everybody else would think regarding that price. Incidently I have been unable to see any marked and real differences between the 8900 curve and the new 9700 bold (having had use of both) that weren't just cosmetic?
