Corsair 700D - Anyone got one?
Find the H50 excellent if I'm honest.
Went from a fairly large air cooler to that, the temps stayed the same and it tided up the inside of my case no end :)
That's what I'm thinking as I've got a Noctua in an Antec 300 at the mo
Sort of what I'm tempted with. Only prob is that I'm running a B3 Q6600 and would like to find a 9550 etc.
Noctua is a very nice cooler, depends if you have the space really.
I used one in a friends build and thought it was well built, but the H50 is a nice neat package.
EDIT: I'm G0 so heat isn't really a massive problem for me.
Got one of the original Noctua coolers, it's a squeeze at the mo and temps are going higher than I want.
Got up to 79 ish with intel burn test at 3Ghz.
Got a 5870 in there too, so it just makes it a bit of a sauna
Order the 700D case, but staying with my Noctua cooler.
Which way would people mount the cooler
== or
I will be putting two of my Noctua case fans into the top of the 700D
Currently I have two fans in a push / pull config
o/
I have a 700D
Loved the 800D when it first came out, but the two things I didnt like were the hot swap door on the front (ruined the look IMO) and the fact the side window went past the "shelf" showing the PSU bay.
When the 700D came out it resolved both my dislikes (with the help of a custom side window)
literally just finished the case swap (and a few cheeky additions) :D
o/
I have a 700D
any pics ;)
Great :D
Ill try and get the log up sometime this week, but heres two mid build sneak previews ....
Back looking at one of these now as I've got a Q9550 and 4GB of PC8500 inbound, need something with nice cooling and SPACE!
Or is it worth getting the 800D with the H50 package?
TB your system looks ridiculously like mine (although I don't have Watercooling).
Love my 800D, with some better fans and a controller the air flow is pretty good. The only problem then is dust build up with all the negative pressure - wish there was an extra intake fan underneath.
what fan controller are you using?
Partly tempted with the H50, but indicated that I'll get better temps under a Noctua
