im trying to overclock my 5850
11 Jun 2006
Middlesborough
i bought the his 5850 on friday and put it in my system saturday morning, i tried using ati overdrive to oc the card a bit but it only lets me take it to 775gpu & 1125ram so its hardly worth bothering with
i downloaded afterburner but for some reason it isnt saving any of the changes i make :confused:
Ditto, I used the overdrive to max mine but it doesn't go far.
I believe there's some issue where only certain makes/models of the card work properly without having to fiddle too much.
Haven't yet tried anything yet myself but will be watching this thread for tips :)
In MSI, beside the Profiles at the bottom, there is a padlock, make sure this is unlocked Before you change and save a profile?
just checked and its unlocked but thanks for the tip ;)
the only reason i want to oc the card is for bad company 2
for some reason my peformance is the same nomatter what graphics settings i have it on tho so maybe i should oc my processor instead
What's your full specs mate? Bad company 2 love lots of cores and ghz.
everything at stock
Windows 7 64bit Home Premium
Intel Core 2 Duo E8600
HIS iCooler V ATI Radeon HD 5850
Corsair Dominator 8GB (4x2GB) DDR2 XMS2 PC2-8500C5 TwinX
Asus P5Q Deluxe
Corsair HX 850W Psu
Samsung SpinPoint F3 1TB SATA
300gig Maxtor SATA
i keep meaning to oc the processor as i have a titan fenrir cooler installed that i bought with overclocking in mind :)
i just keep putting it off but i think ill give it a go now
