BigNG or Aqua Aquaero 4.00 "Powerbooster"
27 Jan 2003
Chesterfield, UK
Anyone using either of these products?
Is the mCubed still supporting the product and do you know if it supports Windows 7 64 Bit? On the site there seems to be a driver supporting all the OS but how does the software work. It does look like W7 64 is supported. Can't seem to be able to Login to the forum.
Need to buy either a "Aqua Aquaero 4.00 Power Bosster" or BigNG ASAP.
Would be nice to run my D5 Vario with either product.
Any issues running 4 pin PWM fans> Just bought 3 Akasa Vipers for the rad and looking at the spacing with the headers I'm not sure the BigNG will support these. Aqua looks better.
BigNG works fine in w7 64bit though i needed to install a fix for the driver otherwise it would BSOD on boot. Software works fine in there as well.
It will only take 3 pin connections
