Why didnt you get tyres that fit on the wheel properly?
Because otherwise he'd not be able to run that amount of poke.
I don't know why I bothered answering that though, it's obviously just a troll post.
How is that a troll post, they look like they dont even come to the edge of the rim.
	It will handle like a pig I'm sure, will ride like a pig too and go like a milk float, but then I guess that's not the point is it, it's 'street' so cool.....I read somewhere. Your car old boy, if it works for you don't give a stuff what I think.![]()
Yes, @ 210Part of me likes it. Part of me wishes it has at least 200bhp to match the looks. Does it?
Looks ok, bit like a half hearted effort though. To pull off the look you are going for it needs to be much lower. Oh, and bin the silly 'D' plates too :/
	Well obviously they are or the car would be sitting on the rims with flat tyres.
Poke should be fairly obvious, it's how the wheels poke out of the arches.
Ah i can see that now, leaves the rim a bit unprotected dosent it.
Be careful you dont get a copper drive you mad for sticking out too far![]()
Well, all I can say is that your rear view mirror is wonky!
