Diet wise, from what I've picked up, small and constant is good (5 a day?) and any white carbs are a no no? I'm a huge lover of pasta, so switching that to brown would be a good choice right? Just need a few tips, links to some recipes etc.
Pretty much, yeah. Small and often. You always need to have breakfast too.
I can't advise though because it seems like you're a bit confused with what you want to do, and what your actual goal is. Do you want to lose weight and get slim? Do you want to lift weights and get more muscley? You have to have a goal and some form of plan so people know what to advise, it's not the same for everything so you need to adjust in accordance of what you want. You have to make everything into a routine, because otherwise it's extremely hard to stick with things and you won't find yourself getting results, routine is both eating habits and exercise.
I will say now, this is a complete overhaul, you can't do things some day and then say "Oh because I ate bad yesterday, i'll eat less today to balance it out" because it doesn't work like that, once you have your routine you have to have some level of commitment to it.
Ah, it probably did sound quite confusing. In a perfect world I'd love to get slim and model toned, but the world isn't perfect and neither am I. So I'm looking to lose a fair bit of weight first, possibly 2-3 stone? Then tone up a bit after. So for now, just weight loss would be my goal, if that makes sense?
Yeah I understand what you're saying about balancing it out, I'm hoping by the weekend I'll have a plan set in stone which I can put my all into sticking to. I'm pretty fired up for doing this, and have bought clothes that are purposely too small so I can see how I'm doing (although not ridiculously small).
Thanks.![]()
Perfect, thanks. This may be a strange request, but I'm off to the jobby centre tomorrow and there's a Tesco opposite, so is there any other things I should look for?
Actually making a list here, so far I've added brown rice and pasta with a pack of chicken breasts.![]()
. Take what you have eaten and work out the number of calories it adds up to as well as the number of grams of carbs, protein and fat.Best thing you can do is get with the calorie counting. Take what you have eaten and work out the number of calories it adds up to as well as the number of grams of carbs, protein and fat.
A 'normal' healthy guy who gets a reasonable amount of light exercise is usually rated as requiring 2500 calories a day. This needs to be adjusted depending on muscle bulk (more muscle needs more energy to work and maintain), lifestyle (i.e. I work all day in an office sitting down so am rated at around 2000 calories). To loose a lb of fat you need to burn 3500 calories more than your body needs. Say like me your body only requires 2000 calories a day, dropping to a 1500 calorie diet will see a 1lb fat loss per week (depending on the make up of the 1500 calorie intake of course). Increasing exercise so you burn on average 500 more calories a day, along with the diet would put you at the 2lb/week recommended level for safe weight loss. Increasing muscle bulk will also increase the amount of calories needed by the body on a daily basis but 'bulking' to increase muscle mass usually leads to fat gain as well. Whilst it can be done, it is generally considered quite difficult to do a 'clean' (i.e. no fat gain) bulk.
Ok, now we have sorted out how many calories we need, we need to look at the make up of those calories with regards to carbs, protein and fats. Keeping a calorie counting log for a month or so will give you a feel for the values for most of the food you eat on a regular basis. There is a fairly good guide here with percentages to aim for near the bottom. When I started keeping a record I was surprised to find that my healthy diet still had twice the amount of carbs compared to protein. It really is worth making the effort in my opinion.
Give the link a read, the BMI and body shape chart is quite interesting as well. You are on the right track and making the right moves so with a little fine tuning you should start to see some nice improvements. Just need to remember it all takes time.
Good luck
RB
Today I decided to get on the scales and it's currently at 17 stone 8 lbs. I'd like to get that down to 15 at some point, but I'm not setting it in stone as a definite goal as I read that it's not the best idea?Thanks, that was really helpful. After following the link and doing the calculator it comes to;
You are overweight by 25.2 kilograms (55.4 pounds)
Minimum caloric requirements: 2427 Calories per day
Limit your food intake to 2062 calories per day.
to lose 2.7 pounds per month.
Your diet should contain at least 96 grams of protein per day.
Would 1500 calories per day be sensible? Next step would be making a calorie log and then go from there?
Thanks again, it's going great so far and I have plenty of motivation.Today I decided to get on the scales and it's currently at 17 stone 8 lbs. I'd like to get that down to 15 at some point, but I'm not setting it in stone as a definite goal as I read that it's not the best idea?
