Hi Folks,
I have just finished building my new Lian-Li V351R but when I boot it up for the first time I could hear very loud fan noise coming from my OcUK Value GeForce GT 240 graphic card. I think it was spinning at top speed.
This one: http://www.overclockers.co.uk/showproduct.php?prodid=GX-129-OK
I know the noise came from graphic card fan because I disconnected the rest of the fans (40mm x 2, 80mm & Akasa Exhaust Blower) to check for the culprit.
Please note that I have not installed/set anything to the PC yet. i.e. I just simply switched it on to check the fans push/pull capability and not setting the BIOS or HDD to AHCI yet, so no drivers etc.
This is my spec:
1) Lian-Li V351R.
2) Gigabyte GA-P55M-UD2 (mATX)
3) Windows 7 Home Premium 64bits (not install yet)
4) Corsair H50 Water cooling.
Question:
1) Is it normal that the fan on a video/graphic card will spin at the maximum if I have not installed the driver or set up my PC yet?
2) Will the fan calm down after I installed everything? bios set up, HDD set up, drivers etc.
Cheers
This is my spec:
1) Lian-Li V351R.
Question:
Cheers
