250 mm Fan
5 Jul 2009
Is it possible to buy these ? Ive searched for ages and can't find any to replace the one that came with my case :(
140mm is only becoming slightly more available so I'd imagine that it'll be a while until 250mm becomes commonplace. This is a bit short sighted of case manufacturers of course as I'm sure loads of people like to swap out their fans.
A quick search for 250mm 12v turned up an American site selling one which comes with a bezel that puts out over 100 CFM. It draws 1 Ampere though so I wouldn't be too keen to put it on a motherboard header.
Edit:
I also found the same one in a UK based Custom PC e-tailer. Of course it's a competitor.
If it's a broken fan for whatever reason a lot of the time manufactures are pretty good with part replacement, especially Antec. Have you tried contacting them at all?
It's not broken but it's a bit slow now :)
Is it possible to have the uk e-tailer by pm ,thanks
