PS3 MW2 New Map Dilema
9 Jul 2009
Manchester
i've just spent £10.99.
downloaded the maps
installed the maps
restarted the system
when i go in game it tells me i need to install the maps!?
what the hell?
im using the correct disk id.
thoughts?
downloaded the maps
installed the maps
what the hell?
thoughts?
Delete the maps; redownload the maps; install the maps; play game? :confused:
Delete your game data (not your savegame, this will be stored in a seperate folder, in the games tab, above the game launcher), redownload and reinstall the maps.
When you purchase the maps and goto the download screen, you will see a list of about 8 files (scroll the list). YOU ONLY NEED ONE FILE but it has to be the one that matches the serial number on the side of your case. Install. That's it.
yeah man, i got that... so they should work.
Is the game 2nd hand? I wonder how common different serials are within the same reigion. The chances are the box and disc would be mis-matched. If that was the case you might have to try all of them.
EDIT: just checked my disc and it also has the serial just above the Dolby logo.
