- 26 Mar 2010
- London
NEC is preparing a new professional-grade 27-inch LCD monitor called MultiSync Reference 271. The 271 uses a 10-bit P-IPS panel that give 98% Adobe RGB coverage, for a wide color gamut. The panel has a wide viewing angle of 178 degrees. Its frame design enables pivot at swivel adjustments.
The panel has a resolution of 2560 x 1440 (aspect ratio 16:9), with 5 ms response time. Its static contrast ratio is 1000:1, with a maximum brightness of 360 cd/m². It takes input from D-Sub (analog) and DVI-D or dual DVI. Backed by a 3-year warranty, the MultiSync Reference 271 is up for pre-order for under 1800 EUR.
http://www.nec-display-solutions.de...df?e=e1s1&fn=NEC_Datasheet_PA271W-english.pdf
• Wide Colour Gamut P-IPS TFT 16:9 display with 10-bit Colour (1 billion colours)
• Outstanding productivity with Picture in Picture, USB hub, DisplayPort connectivity and realtime
• Colour emulation via 3D LUT
• Green productivity through innovative cabinet design, transparent carbon reporting and arsenic-free materials
• 14-bit LUT with 16-bit processing
NEC MultiSync® PA271W
TECHNICAL SPECIFICATIONS
Panel Technology P-IPS
Screen Size [inch/cm] 27.0 / 59.7
Colour Gamut Size / Coverage 98% / 107% Adobe RGB
Pixel Pitch [mm] 0.233
Viewing Angle [°] 178 horizontal / 178 vertical (typ. at contrast ratio 10:1)
Contrast Ratio (typ.) 1000:1
Brightness (typ.) [cd/m²] 300
Response Time (typ.) [ms] 6 (grey-to-grey), 12 (6 white / black; 6 black / white)
Colours [Billion] 1.073 (10-bit per colour)
Horizontal Frequency [kHz] 31.5 - 93.9
Vertical Frequency [Hz] 50.0 - 85.0
Optimum Resolution 2560 x 1440 at 60 Hz
Supported Resolutions 2560 x 1440; 1920 x 1080p; 1600 x 1200; 1280 x 1024; 1280 x 960; 1280 x 720p; 1200 x 1920; 1152 x 870; 1152 x 864; 1024 x 768; 832 x 624; 800 x 600; 720 x 576p; 720 x 480p; 720 x 400; 640 x 480; 640 x 480p
Connectors Digital: 1 x DisplayPort; Digital: 2 x DVI-D
Plug & Play VESA DDC/CI; EDID Standard; VESA DDC2B
Adjust Functions Advanced User Menu; Auto Adjust; Black Level; Brightness; Colour Temperature Control; Contrast; Expansion Mode; Fine Adjust (analog); Hotkeys; Intelligent Power Management; Language Select;
Monitor Information; OmniColor™: sRGB and 6-axis-colour-control; On-Screen-Display (OSD) lockout; PiP; Sharpness; USB
Safety and Ergonomics CE; ERP; TCO 03; TÜV Ergonomics; TÜV GS; C-tick; FCC Class B; PCT/Gost; UL/C-UL or CSA; CCC; ISO 9241-307 (pixel failure class 2); MPR III; PCBC/B-mark; PSB; RoHS
Power Consumption on Mode [W] 59 (Eco Mode 1); 95 (max.); 45 (Eco Mode 2)
Stand-by Mode [W] 1.4
Power Supply 100-240 V; 1.38 A/0.56 A; integrated power supply
Ambient Temperature (operating) [°C] +5 to +35
Ambient Humidity (operating) [%] 30 to 80
VESA Mounting [mm] 200 x 100 (5 points); 100 x 100 (4 points)
ErgoDesign®: Height adjustable Stand [mm] 150 (Landscape mode)
Screen Tilt / Swivel [°] -5 to +30 / -45 to +45
Screen Tilt / Swivel / Rotate [°] 0 to 90 (landscape to portrait mode)
Dimensions (W x H x D) [mm] 643.6 x 397.6 - 0 x 250 (Landscape mode)
Bezel Width [mm] 21.9
Weight [kg] 15
Cable Management yes
Kensington security slot yes
Benefits Adjustable power LED (colour and brightness); AmbiBright; ambix³™; Auto Black Level; Auto Brightness; Auto Contrast; AutoBright; CableComp with Sync Continuity Detection; ColorComp; DDC/CI compatible; Direct Brightness and Contrast; EcoModes; GammaComp (14-bit Look Up Table and 16-bit processing); Integrated USB Hub (2 up; 3 down); NaViSet®and NaViSet®Administrator compatible;
OmniColor™: sRGB and 6-Axis-Colour-Control; Overdrive; Picture-in-Picture Mode; PiP/PbP;
Programmable 3D LUT; Quick release Stand and Handle; Rapid Response Technology; RapidMotion;
Self Diagnostics; TileComp; TileMatrix; TORO™ Design; Windows 7 compatible
Audio Functions Option: MultiSync® Soundbar 90
Colour Versions Black Front Bezel, Black Back Cabinet
Shipping Content Monitor; Power Cable; Signal Cable DisplayPort; Signal Cable DVI-D - DVI-D; CD-ROM; Sales Office List; User Manual
Warranty 3 years warranty incl. backlight
10-bit, Adobe RGB, new IPS panel. very nice and very pricey.
Weight [kg] 15
