- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
New 2000MHz Range of Memory now available from Corsair. Stock will be arriving the start of next week.
Corsair Dominator GT 6GB (3x2GB) DDR3 16000C8 (2000MHz) Tri-Channel Kit (CMT6GX3M3A2000C8) @ £224.99 inc VAT
The DOMINATOR-GT is the ultimate performance memory solution. Limited to only extremely high memory speeds, the Corsair DOMINATOR-GT only uses highly screened IC's to guarantee performance and over-clockability. Using ultra efficient Dual-path Heat Xchange (DHX) cooling technology. With removable heat sinks, the DOMINATOR-GT modules can even be outfitted with additional upcoming accessories with enhanced features. Includes Airflow fan.
- Three matched 2GB modules for use in high performance Intel Core i7 Triple Channel systems
- Outrageously fast 2000MHz performance using 6GB of memory
- Ultra-low 8-9-8-24 latency
- Intel XMP (Extreme Memory Profile) Support
- Airflow Fan
- Density: 6GB (3x2GB Module)
- Speed: 2000MHz
- Timing: 8-9-8-24
- Pin Voltage: 1.65V
Only £224.99 inc VAT.
ORDER NOW
Corsair XMS3 6GB (3x2GB) DDR3 16000C9 (2000MHz) Tri-Channel Kit (CMX6GX3M3A2000C9) @ £164.99 inc VAT
Corsair’s mainstream memory solution for the Intel Core i7 triple channel memory processors and platform. The XMS3 family is Corsair’s mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair’s new XMS heat spreaders, each module is built using carefully selected RAMs.
- Ultra-low 9-9-9-24 latency
- Speed: 2000MHz
- Timing: 9-9-9-24
Only £164.99 inc VAT.
ORDER NOW
Corsair Dominator GT 4GB (2x2GB) DDR3 16000C8 (2000MHz) Dual-Channel Kit (CMT4GX3M2A2000C8) @ £151.99 inc VAT
- Two matched 2GB modules for use in high performance Intel Core i7, i5, and i3 dual channel processors
- Outrageously fast 2000MHz performance using 4GB of memory
- Airflow Fan
- Density: 4GB (2x2GB Module)
- Speed: 2000MHz
- Timing: 8-9-8-24
- Type: DDR3
- Format: DIMM
- Pin Out: 240
Only £151.99 inc VAT.
ORDER NOW
Corsair XMS3 4GB (2x2GB) DDR3 16000C9 (2000MHz) Dual-Channel Kit (CMX4GX3M2A2000C9) @ £120.99 inc VAT
Corsair’s mainstream memory solution for the Intel Core i3, i5 and Core i7 dual channel memory processors and platform. The XMS3 family is Corsair’s mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair’s new XMS heat spreaders, each module is built using carefully selected RAMs.
Only £120.99 inc VAT.
ORDER NOW
Corsair Dominator GT 4GB (2x2GB) DDR3 17066C9 (2133MHz) Dual-Channel Kit (CMT4GX3M2A2133C9) @ £169.99 inc VAT
- Outrageously fast 2133MHz performance using 4GB of memory
- Ultra-low 9-10-9-27 latency
- Airflow Fan
- Speed: 2133MHz
- Timing: 9-10-9-27
Only £169.99 inc VAT.
ORDER NOW
- Airflow Fan
- Speed: 2000MHz
- Timing: 8-9-8-24
ORDER NOW
- Speed: 2000MHz
- Timing: 9-9-9-24
ORDER NOW
- Airflow Fan
- Speed: 2000MHz
- Timing: 8-9-8-24
- Type: DDR3
- Format: DIMM
- Pin Out: 240
ORDER NOW
ORDER NOW
- Airflow Fan
- Speed: 2133MHz
- Timing: 9-10-9-27
ORDER NOW
