Ouch, so that'll be the worst possible tyre to lose?
Oh, I'd been meaning to ask you this; I've seen about 10 clusters of skid marks that veer off into the hard shoulder this week, are these where the air line/s to the trailer bust open/off?
Either front is a bad one to blow, you get thrown left or right depending which pops, had my nearside tyre blown, I'd have been down the embankment & on my side I'd guess, either that or pile into a bridge support ,tree etc etc.
As for the skid marks, yes some kind of full on braking without ABS assistance, an air line splitting will cause the brakes to lock on, as will a siezed drum / caliper etc.
how does the tow truck hook up to the cab is there a special dock?
The recovery truck extends whats essentially a giant "T bar" under the truck and wraps chains around the front suspension, then lifts the cab up, if you look at the picture here, it only lifts the front axle though, letting the rear axles of the unit take the weight.
Its not lifting much weight at all in actual fact, it certainly has to pull a fair weight though, circa 60 tons "Train weight" for the wrecker truck and my cab & loaded trailer I'd guess.
I know I'm a royal pain in the arse on these forums going on about trucks all the time, its appreciated on my part greatly, that when it comes to the crunch (almost!), the "hostile enviroment" thats otherwise known as OC/UK Motors is actually a very friendly, hospitable place, with a good hearted communtiy.
Sincerely, thanks to all for the sentiments.
