- 13 Jul 2009
- Cambs
What would happen if you stuck that in the washing machine with some green clothing dye?
I'm thinking maybe the duvet may turn green but keep the lines?
You would get green lines where the white ones are, as for the rest they may go a dark green depending on the dye. It would prob be best to buy a pillowcase for £4 & test it before going wild on the duvet cover
