or if you're in a corporate setting then you should use Norton Ghost![]()
Hi,
How can i take a mirror of a HDD to put onto another HDD. So all files, setup, installed programs etc. So when I plug it into another computer it will be exactly the same?
Is there some software I could use?
If the other computer is different hardware wise then you may have trouble getting it to boot, just so you know.
If you're in a corporate setting you want to use Windows Deployment Services, not Ghost![]()
Or if your using Windows 7 then it has a built in image creation tool in the backup & restore centre![]()
