Streaming Blu ray quality over the internet ?
2 Aug 2006
Elloughton, UK
does anyone know a good sevice that can stream 720p and or 1080p quality blu ray type content over the internet ( that is cheaper than apple) , weather it be in a download and play service or live.
i checked with lovefilm.com and there service is 640x360 16:9 ratio
I want to play it from my pc to a projector that supports 1080p, or shall i just stick with blu ray rentals ?
Blu-ray quality is generally between 30-35mbps which very few broadband connections in the UK can support so no service supports this kind of audio/video quality. The best you are going to get is compressed 1080p content. On a big screen you can easily tell the difference between a downloaded 1080p video and blu-ray so your best bet is to stick with renting blu-rays.
