Hey,
I have a desk lamp that is perfect after a month of searching. I've had it for a while now, and the only problem with it (not actually the lamp's fault), it the 40w halogen G9 Bulb that seems to output 20 of it's watts as heat. So I was looking into an energy saving (usually cooler) bulb replacement for the lamp.
Now here is the problem;
the lamp it self is a touch lamp with 4 settings; off, low, medium, full. However the specs for the replacement bulb says it is not dimmable. Does anyone know the reason for this or know of a different kind of replacement that I can use? Thank you.
http://www.energybulbs.co.uk/produc...Energy+G9+Spiral+Bulb+in+Warm+White/371196881
